dmoore
NO IT'S NOT RESTORED
2005 Pace American enclosed 2 bike motorcycle trailer, This is the top of the line low profile Legacy Gold package edition, LM712TA2, 12 x 7, Immaculate with little use, one owner & garaged since new, Dexter Independent 3500# tandem torsion axle, electric brakes all four wheels, LED lighting, 3/4" plywood flooring with checkered vinyl, 3/8" plywood sidewalls, polished aluminum teardrop fenders, .030 seamless no screw exterior, two dome lights w/wall switch, flow-thru sidewall vents, 2 removable wheel chocks, torsion spring operated rear ramp with beaver tail, ST205/75R15 radial tires on 5 lug aluminum alloy rims, front mounted spare w/cover, 32" solid core side entrance door, white vinyl ceiling, 24" stainless steel on sides, ATP front, galvanized roof, tie down storage bracket, & much more. Trailer empty weight is 2200# and is garaged at 23350. $4,500
