paint
rbkt65
jerseyville, illinois.
I bought a model of a 65 coronet a990 car. I built my racecar to look like the a990. I need someone to help me find the correct color of 65 dodge turquois paint. In bottle and spray. the kit is a Moebuis brand. I also bought a L700 stub nose and trailer to go along with the 65. TIA.
Which turquoise?
For '65 I see Turquoise, Bermuda Turquoise, Desert Turquoise, Frost Turquoise, Royal Turquoise...
Honestly, I'd just order touch up paint in an acrylic enamel (local jobber or online supplier) in pints and spray cans.
Acrylic enamels won't attack the plastic like laquers do, but I honestly don't know about urethanes.
Another option would be to take a paint chip of your color to the store and spend some time going through all the nail polish brands and colors, they can be thinned and sprayed with an airbrush. But be careful with them, since most are laquer based- use a good primer/sealer first to avoid crazing the plastic.
If the A990 is a resin cast kit you may not have that problem; but the L700 is styrene, so be careful.
