painting on clear coat with a paint brush.
Snake
Mopar Nut
Belleville Canada
Ok here the deal,very afraid about over spray getting on my car.I would like to apply some clear coat inside my front and rear fender wells.The top coat is Acrylic Urethane that is the same as my body color,witch I sprayed myself before going for body and paint.This paint has a shine but not as shinny as I would like.Now what clear coat could I use with a paint brush to apply to get the look that I want.Any ideas.I think this would be a safe way to avoid over spray.also is there a clear that will not need a hardener,just paint and go.Thankssss guys and Gals.
if you do it with a paint brush would it weave lines into the paint where the hairs on the brush meet?
are you worried about over spray in the wheel wells? most of the time you wont even see the wheel wells anyhow due to wheels and clear over spray unless you look hard enough would be almost impossible to see when shadow's hitting it
Hey Snake...............Ever thought of using a FOAM brush.........I think you might be suprised..........no streaks like a reg brush.........JM2C
