Painting over brake fluid contaminated fire wall?
Mopar General Discussions
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    5:38 PM
    My hydraulic clutch master cylinder has leaked down my fire wall, and bubbled the paint is there any way to successfully repaint it. I know this thread should go in a paint forum but i don't see it anymore.
  2. mbaird
    mbaird mbaird
    6,222
    3081
    Dec 10, 2005
    boise, Id
    Local Time:
    4:38 PM
    scrub it down with degreaser then use wax and grease prep...I had sMe issue with leaking Master Cyl.
    Rinse really well
  3. Bodyperson
    Bodyperson Pedal to the metal
    5,573
    7661
    Nov 26, 2015
    NW MONTANA
    Local Time:
    4:38 PM
    Hydraulic fluid should have no damaging effects to paint. More specifics might help us with your situation.
  4. mbaird
    mbaird mbaird
    6,222
    3081
    Dec 10, 2005
    boise, Id
    Local Time:
    4:38 PM
    Most likely using brake fluid.
  5. Bodyperson
    5,573
    7661
    Nov 26, 2015
    NW MONTANA
    Local Time:
    4:38 PM
    Oh, I thought it was hydraulic fluid. I'm sure the few I worked on used hydraulic fluid. I may be wrong.
  6. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    1,864
    1437
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    6:38 PM
    Switch system over to DOT V(5) it’s a different blend and if it is on paint it will not hurt it.
    I used it in my complete new brake system but was told it had a different pedal feeling.
    I stopped feeling pedals a long time ago. Lol!
    • Agree Agree x 2
    • challenger57
      challenger57 cuda57
      207
      15
      Sep 21, 2007
      york, pa.
      Local Time:
      5:38 PM
      Let me make a correction, i ment brake fluid, used wrong terminology.
    • challenger57
      challenger57 cuda57
      207
      15
      Sep 21, 2007
      york, pa.
      Local Time:
      5:38 PM
      It was brake fluid in my hydraulic clutch.
    • Arron tate
      Arron tate T B L
      423
      331
      Sep 12, 2018
      USA
      Local Time:
      6:38 PM
      Hello challenger57,
      I had the same condition with my master cylinder leaking and running down the firewall leaving a nasty streak and contamination of the lip where the steering column goes through the firewall.
      This is how I repaired it.
      Note: I removed the engine to rebuild it so mine was a not as hard to do.
      Removed steering column, master, and brake lines.
      Washed effected surfaces with degreasing solvent.
      Sanded all surfaces as best as i could with sand paper.
      Cleaned surfaces with Prepsol.
      Painted with self etching primer.
      Painted with color matched polyurethane automotive paint. 4 to 1 to 1 mix.
      This was all done with a airbrush from Harbor Freight. Used 10 psi to run the air brush.
      Prep is everything, do a sample not on the car with the airbrush to get get familiar with the spray pattern.
      3/4 And 3 Oz Airbrush Kit
      Deltron®
      Hope this helps.
      happy Mopar :)
      Arron
      • Like Like x 1
      • Agree Agree x 1
      • clifcuda65
        clifcuda65 Old Mopar Geezer
        597
        730
        Aug 11, 2013
        Phoenix Arizona
        Local Time:
        3:38 PM
        I have had that happen several times (owned my 65 Cuda since 73) and in 2003 when I "Completely" Re did my Brakes system (new Front Disk install, new Master Cylinder, new SS Brake lines, new rear wheel cylinders etc. ) I decided to switch to DOT 5 ( Silicone )... I ain't had a problem since !!! Now if it leaks... It hurts Nothing... In fact, I found it Cleans ... LoL..
        Now this is not for everyone... Because DOT 3 or 4 does NOT mix with DOT 5 !!!!! Every Piece in contact with the old DOT 3 or 4 needs to be replaced... Or at least the metal parts have to be super cleaned...
        Note: I made a "DOT 5" badge to put on the New MC so I would not forget... And add DOT 3 by mistake!!
        Getting Old and I tend to forget things sometimes... Sigh~
        • Like Like x 3
        • challenger57
          challenger57 cuda57
          207
          15
          Sep 21, 2007
          york, pa.
          Local Time:
          5:38 PM
        • challenger57
          challenger57 cuda57
          207
          15
          Sep 21, 2007
          york, pa.
          Local Time:
          5:38 PM
          I know the feeling about forgetfulness uhhh what were we talking about. Thanks for all the suggestions. Harbor Frieght is my favorite store.
          • Like Like x 1
          • Arron tate
            Arron tate T B L
            423
            331
            Sep 12, 2018
            USA
            Local Time:
            6:38 PM
            Hello challenger57,
            Sorry I forgot to post the before and after pix.
            Will install new master, lines, and new brake proportion valve to complete the reapir.
            Happy Mopar :)
            Arron.
            • Like Like x 2
