painting the floor pan of my car
jw97neon
utah
so am just now starting to the long process of cleaning off all the undercoating of my 65 dart. once cleaned what should i use to seal and coat it? i am not sand blasting the under side do to not fully stripping the car.
Your only limited by your funds and ability. Epoxy primer will do a good job. It is available from Eastwood.com for $25 a can in a spray bomb.
POR-15. Don't bother spraying it, brushing it will look great as it is a "self-leveling" paint and the brush strokes will go away as it cures. POR-15 is a moisture curing polyurethane so humidity is a bonus. The best example of it that I know of got misted on as it was curing.
