[SOLD] Pair of used Edelbrock Performer RPM closed chamber aluminum heads P/N 60775 and ARP head studs
physixx
Edison, NJ
I have for sale a pair of used Edelbrock Performer RPM closed chamber aluminum heads P/N 60775. These heads are clean and in excellent shape. Ready to bolt on.
https://www.summitracing.com/parts/edl-60775
In addition to the complete heads, I am including a set of ARP PRO head studs P/N 144-4005 that are for use with the Edlelbrock heads
https://www.summitracing.com/parts/arp-144-4005
The valve springs on these heads are dual springs with steel 7 degree retainers and keepers. I measured the springs and I got the following specs
Installed height – 1.825”
Seat pressure – 150 lbs
Pressure @ .500 – 370 lbs
Pressure @ .600 – 425 lbs
Coil bind – 1.20” so max lift on the cam should be no more than .600” to be safe.
The heads have 9 dyno pulls and about 5 runs on them then sat for a while from the last freshen. I took them all apart, cleaned everything and then lapped the valves to make sure the seats were still good. All is great and they are now ready to bolt on and run. I would like to get $1200.00 for everything plus the shipping. The shipping might be a bit high so depending on location, I can meet part way for the price of fuel and any tolls.
Ken
Edison, NJ
