parking brake dash light low oil light gas and temp guage inop
amcervantes
Portsmouth, VA
Well like i said my fuel guage temp guage low oil light and my parking indicator are all not working at firts the fuel gauge went out then worked and now doesnt turn on at all the temp guage was working along with the low oil light and parking brake light but now nothing turns on . im thinking its a ground but i dont know where its at my car is a 72 dart swinger
Where the instrument housing is metal there isn't a ground wire. The panel gets chassis ground through a daisy chain of parts and hardware. Adding a ground wire would help
Ditto on you need a good ground for the cluster. I think that is the only thing that would keep everything from working. The voltage limiter affects only the fuel and temp gages. Post back with results, and strive to use sentences and spell check so we can understand you.
