Part interchangeability Question - 1975 Dart
Neto
Member
Ohio
Does any one have the original parts books from the dealer?
We are missing the windshield wiper linkage which connects the wiper motor to the left side wiper. We would appreciate it if any one can verify which years and models would be the same as the 1975 Dart (by comparing parts numbers in the book).
If that is not possible, if someone has their car torn down at the moment, and could measure that linkage piece from hole center to hole center, & hole diameter, it would be greatly appreciated. (We would then fabricate one if we are unable to find one available.)
Thanks much!
2 speed or variable/three speed wipers
You need the correct link arm for the wiper motor. Any Dart/Duster/Valiant from 73+ should work as long as the motor is the same.
Let me know what you need as I may have some linkage that will work.
The windshield motor is a 3 speed, no variable setting.
(Pushing the knob advances it to the 1st position, and engages the washer spray, and there are 2 more positions after that.)
