Have the complete set up (less clutch rod) from a '72 Duster for sale.
The good, includes pedal set up, 3 speed tranny, back up light harness, frame bracket & Z bar, bell housing, pressure plate, throw out bearing, clutch, drive shaft, interior floor hump, shift lever, bellhousing bolts and instructions as to where they go and direction they go.
The bad, pressure plate has deep gouges where the clutch was worn into the rivets, the inspection plate has a rust through and there is some rot on the lower left edge. You would want to replace all the replaceables - U joints, clutch, throw out bearing. The pressure plate may be salvageable with a turning but the grooves are fairly deep.
Would like to get $300 for everything. I am located in middle Georgia. Please PM me for additional pictures. Will consider splitting this up if no one wants the complete package.
Thanks!
C
Thanks!
C
