[WANTED] Parts needed to complete an 8.75" axle conversion
MadScientistMat
Rating - 0%
0   0   0
Namely, I need the U-bolt / shock mounting plates that go under the axle, and the U-joint straps. Axle didn't come with them. Let me know if you have a set for sale.
DO NOT USE GENERIC U BOLTS.
YOU MUST USE THE ONES WITH THE FLATTENED PART IN THE U OF THE U BOLT.
several suppliers have then typically referred to as Restoration U-bolts
I got mine from Mancini racing IIRC
As for shock plates... Start a wanted ad.
I have a set of shock plates and U bolts available from an 8 3/4 swap that never happened.
