I could be a linkage adjustment also, depending on your year and model, assuming nothing it broken or sloppy loose. There's an access hole in the end of the door shell where an Allen head adjustment screw is located on most models. Another common area for play is the bell crank on the handle itself. If the mounting screw comes loose, it can cause that problem too.
