Passenger side mirror
Twisted71
Hey,
Does anyone know the correct mounting hardware for a passenger side mirror?
Not the ralley type but the one that matches the standard remote mirror.
I think the one inside the mirror housing must be a phillips head with bolt threads to accept the nut from inside the door and then the back one is the same screw as the drivers side. I want to do it right the first time.
Thanks
:blob:
There's a stud screwed into the mirror base that passes through a hole, you drill in the door, and a nut and lock washer are tightened from the bottom side inside the door. The philips head screw goes in just like on the drivers side mirror. Don't forget the rubber base gasket to keep the water out. I bought the mirror and mounting hardware from year one for my Demon.
Terry
