Passenger window front does not move
Frank Dinatally
Pennsylvania
Hi again
The window worked at the body shop but now I can’t turn the window crank at all. Any suggestions?
Thanks Frank
pull the window crank, arm rest and inner door card off. Then put just the crank arm back on. Look inside while trying to roll the window down and you will see whatever is binding. While you're in there lube your window tracks and any mechanical parts that are supposed to move and make sure your roller at the bottom middle of the window is intact. This one should be pretty easy Frank. If you find anything broken I think I have a couple assemblies in some doors in my barn if you need help.
Best Regards,
Jeff
