pcv valve
1970-dart
Vermont
ok so i have (that came with my motor) the Mopar performance valve covers (working on the matching air cleaner) and on one side is the oil cap to add oil and the other side is two Moroso breathers and no hole for the PVC valve.
It looks like i could figure out a way to knock out a spot for a rubber grommet and add a PVC valve. Not sure what to think or do because i have never seen one without the PVC.
........u need the pcv on the opposite side of the breather, which u only need 1 of..put the oil fill cap on the same side as the breather, then use where the fill cap was for the pcv...............kim.......
Put the PCV on the fill cap side and leave the breather(s) on the other side.
One breather is plenty, you could replace the other with a 2nd fill cap.
Problem with the breathers is that they are on top of pipe like peices that are about 5-6 inches long are are welded right into the valve covers. I do see a spot on the cover/fill side that looks like where something would go. so I can cut that out and maybe put the rubber grommet out of my 318 valve cover in it
Thanks
You are gonna have to cut one of the breather pipes off.
the PVC can go on the fill side correct ?? there is a spot on that side ( opposite the breathers)for something but was just not machined out. I believe i can cut that out easier because when cutting it out i can make it the size i need it and just pop a rubber grommet and PVC in it and im done.
I dont think i can just cut the pipes off and just pop in a grommet with out other work because the pipes seem to be bigger around.
thanks
thanks
Yes, you want the PCV on the opposite side from the breathers.
Perfect I left the two breathers in one side and maybe see in the other side with the oil fill On the same side
Thanks a million everyone now back to work LOL
