pedal assembly
tyler_s18
k-member
arvada, co:)
i am converting my 75 scamp to a 4 speed. i am down to pretty much just the pedal assembly and maby the clutch linkage rods. but i found a fellow fabo member with a '63-'66 cuda pedal assembly. will that fit my later model? if not what will i have to do to make it work. it is the only assembly i have found.
You will a set of pedals from a 1967 to 1976 A-body to fit your car.
Same thing with clutch linkage, the stuff from earlier A-bodies will not work on a 67-76 car. Brewers Perfomance has all of these items listed on thier website, but are sort of pricey if you need everything. I have been shopping around and have some parts (cluthc rods, z-bar, etc) are availabe other places for less.
Bob
Are you planning on using the clutch safety switch? If so, you need a set from a 70+ car.
I have all the stuff from the pedals to a clutch fork... shoot me a PM if interested.
