[FOR SALE] Pending. 1967 273 2v .060 short block
Dmopower
Selling a good 273 short block .060 std std main and rods. There is zero wear on the cylinder walls and the last time I checked the main and rods 4000 miles ago the bearings looked great. Can check again. New cam bearings 2 years ago and they look great. Comes with block with crank and rods and pistons in the block. I have been driving this for the last 3 years. I put a 318 in to use the bigger converter on the 999 trans. 150 obo. Block is in Des Moines Iowa 50316
Would you post a photo of the drivers side front of the block under the head.
The stamped in numbers.
