[FOR SALE] PENDING cast crank 225 /6 long block core $50
446acuda
North Carolina
*PENDING*Core cast crank 225, turns freely, pulled due to excessive blow by. It's been a while, but as far as I remember this was a hydraulic cam engine that I used an older, stock solid lifter cam in and is all standard (rod, mains, pistons).The head casting number is 4095778 and it has a car oil pan. I have a cherry picker to load it. $50 pick up in Statesville, NC (about a half hour west of Farmington Dragway that is having their Mopar show and swap meet on May 11) What you see is all that I have.
Just as info, yes this is a hydraulic head. I did that same conversion to a solid cam in mine, it works fine.
PM sent. I've asked a friend for some assistance. We'll see if we can work it out.
