I think first, that 0 deck pistons dont exist. Tehy only go where your machinist sets them, and that's what tells you the effective length change for the block. Then the amount milled on the head's deck tells the other half. Now, as for a $140 set of roller roclers... I'd run 100K mile stock stamped steel first. At least if I punch a hole in them they wont get parts all thru the engine. Seriouusly, you're spending to spend now. I'd run the MP HD thick stamped ones, and use shims as needed to get teh geometry back. Those Ohios, or anything seeling for less than $370/set for aliminums are pure junk.
