Performance clutch?
vntned
Gibsonville NC
What options are out there for clutches if I wanna put a 4spd behind a hot slant 6?
I don't know for sure but I imagine the flywheel is drilled for a 9.5" clutch. Brewers has a 10" conversion clutch that works on the 9.5 flywheel. Measure and ask questions to be sure. That pressure plate can be modified for more clamping force. The local Clutchmasters can help you too. They can modify and even change the disc from organic to metallic or even ceramic lining.
http://www.brewersperformance.com/products.asp?cat=251
tmm
One thing to research is the crankshaft register hole. Seems I recall reading that not all cranks on automatic tranny cars have a deep enough hole for the manual pilot bearing, but perhaps you already have a crank for a manual 3 spd.
