Performance timing
Electrical and Ignition
  1. Mattax
    Mattax Just the facts, ma'am FABO Gold Member
    12,402
    8092
    Feb 7, 2013
    Phila. Pa
    Local Time:
    2:48 PM
  2. RogerRamRod
    RogerRamRod The Older I Get, The Faster I Was FABO Gold Member
    1,024
    632
    Jul 5, 2011
    Chesapeake VA
    Local Time:
    2:48 PM
    I just came across these via a different search. How well does the adjustable PCV Valve work? I haven't found a link to the instructions (yet), but is there a fairly easy setup procedure?
    I see they offer a car club/forum discount, you only need 6 people to take advantage of better pricing. Do you know if they have FABO setup for a discount?
    Thanks in advance for any info
  3. yellow rose
    yellow rose Overnight Sensation FABO Gold Member
    28,824
    25245
    Jun 19, 2015
    Central Washington
    Local Time:
    11:48 AM
    This is a link to the directions page. The Wagner PCV Valve is the best I’ve found. They are simple to use. There is also an advance set up page for engines with low idle vacuum. Their phone tech support is very good. Not sure about a discount for FABO, but it can’t hurt to ask.
    Directions – M/E Wagner Performance Products
    • Thanks! Thanks! x 1
