got a 71 duster and I messed up the dang thing trying to get the draglink off to install headers, now i can't get it off. Went through 2 gaer pullers and 2 pitman arm pullers. What do you think? :salut:
What part did you mess up? Do you have good gear pullers or el-cheepos? The ones that work great but are expensive are the ones with the adjustable cage around them that keeps them from slipping off. But before you buy one of them you might look into just cutting off the pitman arm because it might be cheaper to replace than buying an expensive puller.
Another thing that might help is a little heat applied in the right area. Just be careful you don't melt the lower seal in the gearbox.
