Pic of PM-CLIP679
Rick@Laysons
FABO Vendor
FABO Vendor
Lakewood, WA
see if these are the ones you're looking for.....
Rick
If you could measure the stud hole size and the diameter across the tabs I will know for sure.
I sure appreciate all the work you have done.
Thanks
Al
The diameter of the nylon plug is 1/4". The diameter of the four prongs that go thru the sheetmetal is approx 3/8".
The width of the main body of the nylon clip is just a fuzz over a 1/2".
