I have a 64 valiant two door sedan. i'm restoring it and want to make a cruiser/mild stree car. It will have a 400hp 360 with a cast iron case OD 833. i also have a 8 & 3/4 rear for it. what would be good gear set to run? thanks for any input
Since its a O/D unit,you can afford to go to a higher gear ratio for take off and use a tall tire,28 inch to get back some of the top end.A 3.55-3.73 gear would be niece as it would drop down to a ratio of about 3.08 when you went into O/D,mrmopartech
