1969VADart
Can anyone share some pictures of how the factory sway bar is mounted on your 69 Dart (or comparable year)? When my suspension guy rebuilt my front suspension, he swapped the original lower control arms out for an already redone set that had end link mounting tabs already welded on. However, I have a suspicion that the LCA's that he swapped onto my K-member are not correct for my year because I don't believe the tabs are in the correct place to mount the end links for the factory sway bar that I have. I should have just made him reinstall the original LCA's and installed the aftermarket bar that I had bought, but I didn't do my homework properly and let him talk me into the LCA's with the tabs already welded on from the factory.
Here is a close up of the LCA he ended up installing.
Here is a picture with the LCA on the K-member.
