ok....let's see if i can answer everyone's questions....
yes, i have driven it since i got it back together...drives great...a little better, actually, having the nylon front eye bushings I made and having the spring perches where they belong, instead of 1/2" outboard per side
as far as the plates go....
material cost me nothing ("scraps" at work), it took me one full night at work, because I had work to do as well, and could only work on them during my downtime, but then I still had to blast them and paint them
they are 1/4" steel plate. I cut the main flat area in roughly the same dimensions as the originals, but since they were 7 1/4 plates, i made them a tad longer to accomodate the larger U-bolts. I made the sides for the shock mount and gusset of 1/4" plate, also roughly the size of the originals, but with more squareness to the main plate, that way I didn't have to make any compound angles or anything
then I drilled all the holes at the right spacing for the u bolts and the center pin. after that, it was ready for welding, which, like i said before, i used the arc welder instead of the MIG for SOME STUPID reason
oh yeah, and the opposite end from the shock mount got a 3/4x1/4 strip welded vertically for bracing against bending
then sandblast, wash, and paint with "cast aluminum" ceramic engine paint, so it looks like bare metal, like my front control arms
i'll try to get a view up fron the bottom to show the shape of them
and also a pic of the passenger side spring.....but I think the biggest problem is that I only have 1 spring clamp per side......
