1. dartslantsix
    dartslantsix Well-Known Member
    146
    36
    Mar 3, 2011
    Klamath Falls, OR
    Local Time:
    1:40 AM
    I installed Mopar circle track springs using the AR Engineering hangers, installed in the top hole (lowering the car). Now I have a driveline vibration so I checked the angles.
    The pinion is too far angled up now. (I measured with no weight in the car, not sure if this helps or hurts) To get the pinion back to parallel with the trans, I need to rotate it 8 degrees down. And I'm also seeing that most people recommend an additional 2 degrees for spring wrap on acceleration. This would require a 10 degree shim.
    Here's the question: I can't seem to find 10 degree shims, only 8 degree. Is it okay to not have the pinion down 2 degrees? (this is not a drag car)
    Second question: does anyone make a 10 degree shim?
    Thanks.
  2. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    64,792
    37755
    Jun 7, 2010
    Georgia
    Local Time:
    4:40 AM
    Is it a circle track car?
  3. dartslantsix
    146
    36
    Mar 3, 2011
    Klamath Falls, OR
    Local Time:
    1:40 AM
    No, handling focused 67 Barracuda.
  4. RustyRatRod
    64,792
    37755
    Jun 7, 2010
    Georgia
    Local Time:
    4:40 AM
    I was wondering the reason for circle track springs.
    • Agree Agree x 1
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      16,551
      4900
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      3:40 AM
      Can u raise the tail end of the tranny. What year is ur car and what is it? Kim
    • dartslantsix
      146
      36
      Mar 3, 2011
      Klamath Falls, OR
      Local Time:
      1:40 AM
      67 Barracuda with an ax-15 trans and Ford 8.8 rear.
