Well you're close............??? Normally the angles (engine and yoke) are set so that when there is a load on the drive train (during acceleration) the tranny and yoke are at the same angle. So if you set your pinion angle with the car sitting still (static) you need to have the yoke about 2 1/2 degrees down relative to the engine/tranny angle. Now other people might say 2 degrees and some might say 3 degrees ....to each his own. The point is that when you accelerate the pinion yoke will rise up a degree or 2 at which time it will be at the same angle as the engine/tranny. Make sense??THAT was quite an example, hard to wrap my head around it. I just assumed all parts would be moving equally. So on a lifted 4x4, with an extreme driveshaft angle, all is well if the rear end yoke and tranny are in line?
Thanks...there is a "HAPPY PLACE" for the pinion yoke as demonstrated by all factory cars (no vibration at all). That's why they invented pinion angle shims for us hot rodders!!!!Yes! You would really notice any vibration while cruising, but not notice necessarily while under WOT. Great post Treblig!
The angle of the driveshaft (4 X 4s) doesn't hardly matter at all. What matters is the angle of the engine crankshaft/trans relative to the rear end pinion angle.....WATCH:
