pinion angle
Rapid Robert
Lincoln Nebraska
63 dart 360/904/7&14 circle track. I am raising the eng/trans so I can run good flowing magnum ex manifolds. what is the max degrees offset I can have on the pinion angle? I know I want them within .5 degrees (iirc) of each other & offset parallel. thank you for your time. RR
From what I have researched in the past they recommend 1-3 degrees and parallel.
