Pinion Seal, and Axle Seal help......
Duster Fan
Smartsville, CA
I've got an 8 3/4 Dana Sure-Grip Posi Track rear end(with a 742 center section) with Moser 30 spline axles. I've recently developed a leaky axle on the passenger side, I'm not sure as to what seals are currently on their.
Where is a good place to shop for the seals and is there a specific kind I need to get? Right now I've got Green Bearings on there.
My Pinion seal is also starting to leak, now do I need to get one for a 742 center section? (this one:http://chucker54.stores.yahoo.net/nat834742cas.html
Or no?
Any help would be appriciated.
..........Yes, u need a seal for a 742 center.......I got a Timkem brand 7216 pinion seal from either Rock auto or O'riellys for about 20 bucks, axle seals about 15 bucks each....15460 is the CR seal #, get them to cross reference it....kim.........
