aaronk785
I'm freshening up my 340. My top ring groove in the piston measures .083. Is this to loose for a 5/64 ring. Second groove is at about .079. Thank you.
That's less than .005" larger than 5/64. I don't know if that's out of spec, but it seems like a small amount of wear. Does anybody have the spec on it?
I’ll see if I can find the Chrysler spec because I believe there is one, but when the ring, especially that big, heavy one is that loose in the grove it looses seal every time the piston changes directions and it will just continue to beat the ring groove out of it. That’s why some of the power adder stuff has hard anodized top ring grooves.
I'm not disagreeing. I'm wondering what the spec is. It stands to reason if the ring is 5/64, then the groove has to be bigger, because there is clearance. That's why I am wondering what the spec is and what the tolerance is.
I’ve read where guy have had the top re grooved bigger and used an oil ring as a spacer. So about .020 bigger. What do you think?
Hi all. I just read an article by weseco pistons on ring grooves. They say you don’t want more than .018 behind the ring because it takes to long for the pressure to build and push out on the ring. The last several sets of rings I have bought have a narrower top ring horizontally. So now I have over around .040+ behind the top ring. They just started doing this awhile back. Just got my short block together and read this. Why would the ring companies do this. And should I worry about it.
