Pitman Arm interchange
halibut
Member
Sanford NC
71 dart with 318, PS and AC. removed worn out pitman arm and replacement (Moog 7074) will NOT work as its splined hole is 1/8" too small to fit on steering box shaft. I know Ma mopar had 2 different sized sector shafts and I may be in that mixip. Any one out there have a solution or Part #? I don't want to have to purvhase all new (73 and up) parts.
71 Dart Swinger in NC
looks like someone changed out steering box....cause a 71 should have ths smaller spline..
two choices...either find a 71 steering box or go with the 73 and up parts
