placement of factory GO wing?
moodman1962
Hi I have a factory go wing for my Duster, I need to know what the measurments are so I can install it in the right location?
Someone must have put one of these on?
Do you have the factory mounts also? Some trunk lids have cut outs from the factory, specifically to mount the hardware, sounds like your trunk lid doesn't.
I think I've posted that info on here before, I'll search my old posts to see.
It would be a lot easier for you to find a lid with the cut out, and if nobody chimes in with dimensions, I'll gladly get you some tomorrow.
All the best,
Giles
I am pretty sure Year One sells a template for it. It's pretty cheap too.
when i had my 72 duster and added the go-wing i bought the support brackets as well and mounted them then useing a center prick punch against the underneath of the panel then drilling them out it turned out nice
