Placement of Jack instructions DECAL?????????
71dart340-6pac
Active Member
Oregon City, Oregon
Not sure if this is the right forum for this.....I want to know where the proper location for my jack instruction decal goes? Is there a pic or dimentions to use?
Please help! and thanks in advance for your help!
My car has the original one on the underside of the drivers side trunk lid. It looks like it was just slapped on as an afterthought.
This is on my 73 dart custom. It is bone stock all original. I have seen the sticker on the pass side, driver side and in the center so I think it was just a whatever where ever deal.
Same here, mine still has the original slapped on in the middle cavity.
Not much care was taken for proper alignement, or even bubbles underneath.
I think you'd be safe putting it anywhere on the inside of the trunk lid, as long as it's in the recessed areas. As everyone else said above, bubbles, wrinkles and all are appropriate.
I think the wrinkles are from moist trunks.... mine is wrinkled too and I had moisture problems too. I know the assembly guys didn't give two craps about quality but I can't figure out you can put a sticker on with large air bubbles.
