plastic exhaust manifold trays 273 drivers exhaust manifold
737jetdr
Martinsville, In.
I saw an engine on a 66 barracuda formula S at the Indy Mecum auction last week. It had 2 hard plastic trays that sat on top of the drivers manifold that protected the spark plug boots from heat. Has anyone else seen these or know where to source them? I've never seen them before. I should have taken a pic but didn't think about it. Thanks.
They are metal not plastic. I don't think they are repo-ed
The later 340 versions MIGHT be different than the 273 version but here is a link to get you started
273 version
Exhaust Manifold Gasket W/Heat Shield# 2465845 - LH - A - Body - 1964-68 - NOS - SHIPS FREE TO LOWER 48 - Blue Star Performance
Our 67 had them, I've got one somewhere in a drawer,
I have what I believe is the original 67 273 in a tote.
Steve burst my bubble
Looks like they are 70s factory replacements.
OLD plug wire might have needed them but I dont see modern wires needing them.
But for authenticity I get it
I have a set that I believe came off of a 318. At least I pulled them from a 318. Maybe they weren’t original to the engine. I recall that mine look a little different than the ones pictured. I’ll get some pics when I get home.
How many versions are there?
They were probably aftermarket.
This has been posted before. I think there are some other numbers out there but if it looks like one of these the it is for the years that the form matches.
The non-340 ones.
Alan
Thanks for the info everyone. I use the high temp wire protectors that slide on anyways. It's nice to know they are out there.
I think I'm gonna remove the one on my 273...
It gets in the way and modern wires probably don't require them anyway.
