play in rocker arms
7dart0
peabody,ma
my 360 magnum has been sitting a while and there is alot of play in the rocker arms. is this because of lifter bleed down? will i need new lifters?
tom
tom
If it's a hydraulic roller setup, then it is lifter bleed down.
You can tell by pulling up on a rocker tip of one of the loose ones, and if it you feel a spring loaded type feel to it then it's bled down hydraulic lifters.
(It takes a little pressure to lift them. (maybe 3-5 pounds?)
There ya go then.
Probably just bled down lifters and sounds normal to me.
