Please Help 911!! Vacume Leak On My Slant Six PICTURES Inside with details
Dash8264
Member
OKay So Here is the Problem There is a tube Coming from My Intake Manifold I guess there is supposed to be a hose going to it Or a plug. But I gues whatever was there fell out now it makes a huge sucking noise and Myt motor doesnt run well. Here are a few pics showing the tube Missing and a pic of the carb with a few open Hose Fiting maybe someone can help Me figure out how to plug it back in or what to do cause Im lost and need to drive my car. Thanks guys And by the way my Valiant is a 66 and the motor is a 70 something.
What year is your car? I'm thinking it's a newer slant six somebody put in there. The one should go to the power brakes if you have powerbrakes, looks like the ones on the carb goes to the charcol cannester like i said late model stuff, You can plug em but make sure you have a pvc vavle hooked up
Sorry just noticed the year, 66 didn't have all the emission crap plug em and make sure you have the pvc hooked up, And the vacume on the dist, should be hooked to small port on carb, one that only has vacume when your giveing it gas no vacume at idle
Good Job mr.318 :cheers: Jumped on that one quick :happy10:
