7T Swinger
- Joined
- Mar 31, 2009
- Messages
- 127
- Reaction score
- 65
Photo attached
There is no way to know the actual assembly date.
The date one the tags is an expected due date, but lots of factors could affect whether a car was built earlier or later than that date.
I'd have to check my book later, some combos were not available, some labeled not recommended.Black with blue & white interior???? That is a very weird color combo. Can that be right?
I was just curious if it was on of the not recommended ones like turbine bronze with a copper interior.I wasn't doubting you, Alan, just surprised that that combo would be available. I wonder what's in the car now? There seemed to be black paint on the tag, all right.
That decoder can be a PITA, lining up the letters and numbers can take a couple attempts. But for the most part, it works well. Not all the codes do show up, but you can usually figure them out using the codes that are listed elsewhere on the site.Any way you look at it that’s a cool car… but I’m definitely biased
I don’t recognize the buckets but they look like late 60’s Mopar to me.
Some time back I plugged the numbers on my fender tag into the 67 to 68 Mopar Fender Tag Decoder on MyMopar Mopar Codes - MyMopar.com - Mopar Part Numbers . Unfortunately, the links to the decoder and many other tools on the page are not working today, maybe someone who’s a member over there can find out what’s going on. Regardless, I did find another direct link to the same tool which does work today MyMopar - Mopar Forums & Information - 1967-1968 Mopar Fender Tag Decoder
Even though the instructions say to use extra spaces to align the codes it doesn’t work when they are lined up visually. In fact, it limits the number of characters you can type in the field but it seems to work when you count the spaces using the space bar, must be a function of graphics properties. The decoder seems to work quite well except for the “unknowns”, I guess it has a few gaps in it’s database.
I ran the numbers I see on your tag:
So, according to this decoder I guess we can add a little more detail for the possible original state of your car. Obviously, the interior could have been changed and the unknown seats are good evidence of that.
Here’s my tag and a snapshot of the report the decoder gave me, from everything I know about my car I believe the decoder is correct, except the “unknowns” which I can find no further info on.
Your post actually caught my eye because it looks like our two cars were very likely built within a couple of days of each other but as Alaskan_TA says there’s a lot of factors affecting the actual build date so probably within a week of each other for sure!
Good luck with your project, it looks like a way better start than I have!
He hopes to have it back up in a week or so. I contacted him about it, I use it often.This USED to be a great decoder for 67 and back. Nothing with spacing or anything needed. I can't find decoder on the site anymore??I also noticed the site format has changed. I emailed the owner to ask what's up. We'll see if there is a response.
Link
DodgeCharger.org – The Leader of the Dodge Rebellion
Head rest style looks to be '68 or '69 for bucket seats.Does anyone recognize them?
I don't see the seat back catch release. Is there one?
'67 didn't have a catch. '68 did.
