7T Swinger
- Joined
- Mar 31, 2009
- Messages
- 127
- Reaction score
- 65
Re: ‘73 - ‘76 front calipers
Banjo bolt
Caliper mount bolts
Thanks
Banjo bolt
Caliper mount bolts
Thanks
Or....tighten til it strips n back it off 1/4 turn...
Wrong!
Tighten them until any more would strip them.
Banjo bolt
Caliper mount bolts
Thanks
Tighten and loosen the banjo bolts half a dozen times and you will find the bolt rotates farther in as the parts seat & mate together better. it's somewhere around 15 to 20 ft lbs for the banjo bolt.
Much appreciated.
A bunch of smartasses huh?
Those manuals are a must, because you know you will have the same question about something else eventually.
