Please identify these wheels
hotrod swinger
Sooke
Anybody tell me who manufactures these wheels and the model name?
The front and rear appear to have different center caps, so they may be a mixed set, but to me, I believe it is the Cener Line Convo E.T.
Looks to be both AR62 up front, and Convo ET's on the rear. Couldn't find a picture of anything narrower than a 15x8" Convo ET, those had the ribs inside. A 15x7" Convo Pro also had the ribs.
Count the holes... the wheels in the two photos have a different number of holes...
Well, the rears are certainly centerline pro-stocks, convo version. I thought the fronts were centerline pro-stocks too, because of the dual pattern, but.....
I compared to my centerline 15x4 pro stocks (which also have the dual pattern) but mine have 14 large holes, yours show ten. Design change?
Centerline pro-stocks have been out of production for years even before Centerline Tool folded.
I don't know who is making "centerlines" now, I suspect china.
Edit: my centerline pro-stocks rears have 14 large holes too, they are not the convo version.
There are more than two photos, so nobody knows what two photos you are talking about because you posted a new reply, instead of replying to the specific post you are referring to. It really helps people understand what you are trying to say if it is important.
American Racing AR62 Outlaw II
You can get them in 5 x 4 bolt pattern in 14" rim or 5 x 4.5 in 15'' and 16" rim.
I thought about the AR62 for the front, but if you look at the holes in the original posters picture, it looks like a thinner stamped steel material, not the much thicker material you would see used on an aluminum wheel.
I actually have some Enkie wheels real close.
