Please post pics of your fiber glass doors
here are my VFN doors on my 68 barracuda.
VFN puts a vertical lip on the door to attach the lexan.
I used all of the stock door hinges with round stock pins and clips.
Stock door lock and striker
stock exterior door handle
stock actuator hardware but a homemade interior handle
the lexan support is aluminum square stock with screws.
I will be changing some stuff for the street and track
I will be removing the vertical lip to and go to a flat surface on the top of the door.
I will be making a special bottom to the lexan window with Zues clips to be able to remove the window for street use and i will be adding the lexan to roll cage clips because the window gets super floppy over 100mph.
Here are pics
Here are pics
Thank you very much bro
a **** ton.
best money per pound you can spend. i think the stock doors even with lexan were like 50lbs a side.
I use to keep track of all the weight i took off the car but dont know where the exact notes are. All i can say is night and day
