Kansas,
http://tinyurl.com/c8qghb
This is a nice car I just found on EBay. Brakes/ rear end done. If I had the $$ I would grab this car.
Item number: 200320868746
1965 Dodge Dart 170
Original 225 Slant 6 converted to 1978 2 bbl aluminum intake. Added electronic ignition and solid state voltage regulator. Pulled motor and installed new Cloyes roller timing chain and gear set and added new Melling high volume oil pump, and changed out all of the old engine gaskets with new Felpro pieces, and installed new freeze plugs.
Installed manual front disc brakes from 1975 dart, with new ball joints, new tie rods, new upper and lower control arm bushings, and new strut rod bushings.
Installed 8 3/4 rear axle with 2.92 gears out of a 1965 Coronet, refurbished brakes with new 10 x 2 brake shoes and wheel cylinders.
Body is good shape, a few little dents on the front chrome trim. Rear tail light bezels have some pits in the chrome. Rust in the lower quarter panels, along the bottom lip of the trunk lid, over the rear wheel openings and the driver front floor pans.
Front seat cover has rips on the drivers side, after market carpet is faded and needs replaced, door panels are wrinkled and faded, steering wheel has cracks. Instrument cluster bezel is in good shape, as well as radio and heater controls/bezels.
All of the glass is good, all of the lights work, and all of the gauges and switches work. The radio comes on, but the speaker is old and no sound comes out.
Car is mechanically sound, a good daily driver, and has free and clear Kansas title. Payment is expected within 7 days, car can be stored free of charge up to 30 days after the auction, after that some arrangements will need to be made. I can help load on a transport if needed. If you have any questions please call me at 316-312-2945
Many more pics here ==> 1965 Dart 170 pics
