bradford Professional at nothing FABO Gold Member Joined Feb 3, 2011 Messages 67 Reaction score 39 Location N.C Apr 22, 2021 #1 I’m trying to figure out if a 70 Plymouth duster pop out quarter window will work in a 73 duster? Does anyone know if they will work? Thanks
lenky1 Well-Known Member Joined Jul 30, 2014 Messages 872 Reaction score 639 Location illinois Apr 22, 2021 #2 Im pretty sure it will the only thing is you better make sure you have the correct interior sail panel so it doesn't interfere with the hinge
bradford Professional at nothing FABO Gold Member Joined Feb 3, 2011 Messages 67 Reaction score 39 Location N.C Apr 22, 2021 #3 lenky1 said: Im pretty sure it will the only thing is you better make sure you have the correct interior sail panel so it doesn't interfere with the hinge Click to expand... Okay thanks. My sail panels are from the same car, a 70 duster. So I hope they will work.
E ESP47 Well-Known Member Joined Jul 3, 2009 Messages 2,636 Reaction score 1,680 Location Sacramento, CA Apr 23, 2021 #4 I believe 70-72 Dusters used a chrome handle and 73+ used a plastic handle. If I remember right, the frame and glass will fit just fine but the hole is drilled in the glass in a different spot so you'll be forced to use the chrome handle.
barbee6043 barbee 6043 FABO Gold Member Joined Jul 20, 2008 Messages 21,806 Reaction score 12,308 Location Shepherd, Texas ( SE Tx) Apr 23, 2021 #5 Anyone need a 71 Righ tside Duster pop out quarter window?
