Poly BB Motor Mounts
TheContractorDude
Hawaii
Thank you,
So I purchased some replacement poly mounts from Mancini cause Schumacher was sold out. I have the factory BB K-Member but am using the Schumacher LH motor mount because it came with a more common insulator and the poly mount that I bought will not work with the slightly reconfigured left hand bracket. I can't find my OG left hand bracket and was wondering if someone has a picture so I can see the difference. The rubber insulator on the LH side is compressed so much that my oil filter is hitting the K-Member so I decided to go poly to see if they would last longer and to see how they would feel as opposed to rubber.
This is the side that attaches to the bracket. The other side will bolt on to the K-Frame no problem. The RH side is not an issue.
Thanks
