How do the plug readings look and have you had to stagger jet the carburetor to clean it up? My first line of thought is that the runner dividers need trimmed back 90 degrees from the carburetor flange to the port floor. Look at the odd inverted triangular window from the center of the plenum to the outside runners. I may be wrong, but to me it just doesn't look like a happy flow path for the mixture to make it's way out of the plenum to the inside cylinders. Think about it plowing into the floor and then having to back up to make the turn around the runner divider.
Well, admittedly I'm not either! But in this case, it's not just airflow, but mixture and charge distribution. I'm only going by the single plane manifold designs I've with the carburetor flange radiused to improve airflow. It usually follows the criteria if looking through the carburetor at WOT the runner divider will come close to intersecting the center of each diagonal sets of barrel, even if that means the dividers have to pushed back a little to establish that. Your plug readings may help determine some of what is happening. But yes, I would like to see his input here, too, as I believe he posted an article a while back on correcting the flow problems in a Super Victor.
This is correct. You have to take the hook out of the divider. And thin them. Then you need to measure the port window at the flange and then measure the opening at the plenum and figure out how much taper you have.
Explain the "Hook in the divider"
And are you referring to sq area of plenum vs port exit ?
I was hoping @pittsburghracer would chime in
I really hate to comment on other people’s work. Mainly because lighting is so critical in seeing what is going on. No only my porting bench but my shop looks like an airport lit up at night. Close your eyes and run you fingers from the carb flange down each runner and down the vanes. Think radius while entering the runners. Would a short turn like a 90 degree turn (I don’t think so), thinned vanes but not sharp edged, no humps, divots, etc. the hardest thing about porting an intake manifold is getting it in the 36 different positions to get it right. I have V-blocks, different sized chunks of wood, and things to lean it against.
I have a hard time putting what my eyes see into words, so let me see if I can explain it better. Where the 7 and 8 ports meet at the plenum, right there I would take that wall and lay it back. View attachment 1715828950
Maybe this will help. Where the black is, I would lay back until you get the opening bigger and get rid of some of that turn. If the end result is a very sharp point where the two ports come together, just put a radius on it. Where the red is I would go in there and pull that down and get that big hip out of that area. Where the blue is I would pull that back towards the number 7 port. I would start by grinding on that common wall between 5 and 7 on the 5 side and move that hook out. I hope that helps explain it a bit better.
Just to confirm on the area, I take it that you’re measuring the area of each runner entry in order to equalize the runners entry points as much possible. The more I work with porting the more it reminds me of making knives by hand on a slack belt grinder. You have think about every single action and every movement all the time. In other words, IT’S HARD!The shape of the opening of the runners is very important. It seems counterintuitive but looking at the number 5 and 6 runner openings you will see how the divider at the floor is hooking away from 7 and 8 and towards 5 and 6. You need to move the bottom of the divider out of the way. And shorten it up at the bottom. I would also lay the outside wall of 7 and 8 where they open into the plenum back some. You have to make sure you don’t break through there. Even if you do, it can be easily welded. I don’t remember how much materiel you have to work there. And yes on the area.
Two thumbs and eight fingers, each is a unique measuring tool. Start fingering (not trying to be cute) and you can feel how tight or loose things are at various points on them.Honestly its not possible to get calipers in to measure width .
View attachment 1715828966 You can use an inside calipers to measure in your intake manifold, setting it to or measuring it with a scale(ruler). This is how my grandpa who was a pattern maker made patterns measuring with a shrink rule.
