Porting Mopar 318 smog heads.
Mopardoctor
318 Duster
Denmark
Home porting a set of Mopar 318 heads
This is my first shot of porting a set of Casting nr. 4027163 smog heads after the internet.
Have no flow bench, but it would be realy nice with some flow numbers after many hours of porting and surfing the internet with some of my own theorys about porting.
Gasket machting.
Standard metal gasket for 318 bolted over head and marked up.
Home made template for pushrod pinch.
Finished with gasket machting.
Here you can see the difference between old port vs. ported, and how far i dared to port
in mm.
Sorry, I don't "receive" phacePlhant. No reason in the world, tho, that you can't lash up your own flow bench at least accurate enough for comparitive numbers. Google it. Basically it's a box to fit the chamber over, a variable speed control (lamp dimmer) on a shop vac, and pressure gauges, AKA manometers. And, a way of controlling and measuring valve openings
One I found on a quick search......
http://www.diyporting.com/flowbench.html
http://www.tonydrews.com/Flowbench/FlowBench.htm
"There's a forum" LOL
http://www.flowbenchtech.com/forum/
My org. bowl was 37,13 mm(1.46 inch), now it´s 39,30 mm(1.54 inch),
and made into trompet shape under valve seat to create a veturia effect
right under the valve.
Valve guide is cut 3 mm(0.118 inch)
The seats will be cut to 1.88 inch valve 3 angle.
Would to realy like to bye the diyporting one, but not for now.
LOL. Well the point is you can BUILD one that's fairly functional, and will at least give you gain / loss over "what you did last."
3 angle Valve job is hand cut with Neway 60/46/31 degrees.
Found a set of 1.88/1.6 inch vavles for 90 $ at Ebay, this will give me an intake bowl at 82.3%.
Intake bowl with 1.78 valve is at 86.9%.
Taking the sharp edge from 60 degrees and cutting again.
Finished the valve job, the 46 degrees is 2.5 mm now.
My stem height is now 47.94mm (1.887 inch).
The chrysler "bible" says 1.907-1.937 inch, the valves is sitting high in the chamber,
but read on the internet that they will settle with 0.02 inch after running the engine.
And the chamber is 67cc with 1.88/1.6, before with 1.78/1.5 valves it was 68cc.
So when should I send you my 302's to play with........
I´m living in Denmark, that´s the reason why i´m doing these heads, a set of Edelbrock would set me back 2000 $ plus Danish tax and shipping.
But go a HEAD and port them, also look at 1wild&crazyguy 318 head porting for the average joe thread, which got me going.
And i don´t have a flowbench like him.
Exhaust cut at 46 degrees is 2.8 mm.
The exhaust bowl is now 33.15 mm (1.305 inch), also with a small trompett shape.
81.5% with 1.6 valve, 87% with 1.5 valve.
Thats how far i dared to go.
Gasket match for 1 5/8 headers.
Nice work, makes me wish i had spent more time on mine and not rushed to put it back together just so it can sit there for another year :(
They are soon of to milling 1 mm (0.04 inch) on both intake and head.
These heads will be put together with Comp Cam 901-16 springs,
744-16 spring retaineers, 504-16 valve seals, and 604-16 valve locks.
Head gasket will be Mr. Gasket Head Gaskets 1121G 0.028 inch compressed, 6.177cc.
Cam choise is open, but think it will be Comp Cams XE 262 H with the org. 904 converter.
Intake valves now have a 32 degrees backcut 0.8 mm wide (0.031 inch), the valves are from Enginetech.
When you say "smog head" you need to understand every single factory open chamber small block head is a "smog head". Even the coveted X heads. Same basic chamber and port design. The 318 open chamber heads mirror that, only in a smaller port version. Most any open chamber domestic V8 head is a "smog head". That was the whole purpose behind the open chambers. For better emissions.
Nice port work, btw.
Nice work,indeed.. You took your time,and it paid off Congratulations.
Look forward to seeing hp/tq numbers once it is finished.
What carb/intake/exhaust will you supply it with?
Will make a dyno on the wheels before and after with same cam(org. cam), just to see what gains there is with heads only, then i will put in a XE 262 H.
The exhaust is 3 inch dual delta flow 50, Headman Headers, intake Edelbrock Preformer, Holly 1850 600cfm.
Will port macht the intake to the heads, like oldmanmopar wrote about once, they can be as much as 1/8 inch off, and mark the intake up with the heads on the engine.
Will bye new pushrods from Comp Cams after blueprinting lenght (with 0.03-0.04 preload), this is made on a working man buggett, these heads now cost me 390$ with new valves and milling (gave 200$ for the heads in Denmark)
More will follow this thread in winter.
The 3" exhaust is large for your setup and will likely cost you some torque but it should be a good runner regardless.
My cylinder heads were just laying on the shelter, so i gave it a little valveseat cut on 15 degrees both intake and exhaust, and fine grade polish valve lapping.
Can see all my old pictures is gone here, so here is before and after, seat is blended in by hand with a small radius under 46 degrees cut.
Made in a "trompet form" under valve to create a venturia effect and turn air round the seat.
