[SOLD] Positive and negative battery cable sets 67, 68, 69 A body SBM
moparmat2000
Grand Tetons
I have 4 sets of 67, 68, 69 A body battery cables for small block V8. These are new made by me. Correct gage and color wire, heavy duty terminals. These are correct length unlike the supposed repops that are about 3"- 4" too short. These also have a high heat woven insulation on the end by the starter motor similar to OEM to protect them from the exhaust manifold heat. The other supposed repops do not have this. You get 1 pair of positive and negative cables as shown. Pix are shown mocked up in a 67 A body. Price is $168.30 shipped all 50 states. Located in west Texas, I accept PayPal.
Let me know if or when you plan on fabricating big block cables for 69 Dart. Im good for now but had to wait for months to get the repop negative cable.
I have friend researching the positive cable length on 67-69 BB cars. Should be the same as small block at the battery and relay. Negative is 22"
Yes. The negative rrpop was back ordered last year. Not sure who was making it for the big stores. But I remember paying around $75 for that.
Do your battery terminal ends appear as original?
Is that negative cable factory correct for the ABodies only having one cable? I know in the retail stores there is a second small wire in addition the large gage cable. Thank you.
dibbons to answer your question, 67-69 A body use a single wire negative cable, and have an engine to firewall ground wire. 70-72 negative battery cables have an extra 12 gage negative to body ground at the radiator support with a 1/4" ring terminal. This additional ground wire I believe is 14" long. I am going to work on doing those next. Some of my parts I ordered are on back order currently. Positive for SBM in an A body are the same from 67-72. I think the auto parts store negative cable is a generic kind of a deal, so it has that extra ground lead to be used if needed or just clip it off. It would not hurt to add in a battery to body ground on an earlier than 1970 car.
Your negative cable is correct for 69? No extra wire pre-70. Do you sell just the negative cable? If so what is the price?
