Valvebounce
I did some racing last weekend.
Motor threw the fan and powersteer belts. On the last pass, it also lost one torque converter bolt, and stripped the helicoil on the opposite side.
Motor is a stroker.
Given that there were issues at both ends of the crankshaft, could an imbalance issue be playing a part?
The people who supplied the stroker kit advertise that they balance them to 1gram.
I've had other cars where breaking flywheel bolts, and having flywheel bolts shake loose was a common problem. (Even when the bolt holes where tapped out, loctite primered, and loctited in)
The crank had a number 5 main journal that was 1 thou oversize when the kit arrived. So I do have to wonder how much care has been taken?
Motor is a stroker.
