Post your stock stroke SB combos
mshred
The Green Manalishi
Give us the details (or as much as you care to share).
Engine combo (cam, heads, carb, etc.), compression, car weight, gear, converter, tire, etc.
And yes, power adder vehicles are welcome to be posted too!
Let's hear how you are getting it done without a 4" arm in there
LOL...top secret **** here...LOL
71 Dart...360 .060 ...did not sonic test the block...assembled back in 2006....
Wiseco (MP) flat top pistons....sticking out of deck .012...pistons are actually for a 3.51 stroke crank...CH is .035 higher then stock 360 piston.....Hughes CNC Open chamber heads...yes open chamber...cut .030....with MP .026 thin head gaskets....
Chinese no name H beam rods..weighting in at 630 grams..stock cast crank internally balanced.
Hughes 260/264 .050 ...3 degreed advanced at 103...Flat tappet cam...no roller needed...Crane 1.6 roller rocker...Hughes 1111 springs...Gross lift around .630...
Edelbrock Victor intake...Hooker 5204 1 3/4 headers...with tethers...
MP Race Electronics with MSD 7 AL2 ....
QFT 950 E-85....
Turbo Action 4200 series 8 in converter (5000+ flash)...paid 200 bucks for it off ebay....904 built by me...and Tranzact Pro Transbrake...
8 3/4 with spool ...4.56 gears...Housing narrowed 2 inches each side... Hoosier 10 x 29
8 pt roll bar...frames tied...ladder bars and coil over shocks...
RMS UCA with adjustable strut rods and Strange brakes in front..
Car weights 2850 with Driver...has gone 10.334 @ 128.22 with a DA of 2700 ft in Bakersfield....Oct 2013...
I guess no one else want to post....super secret stuff you know.....LOL
71 Demon...360 .030 SRP flat top pistons...10.5 to compression....ebay H beam rods....Modern Cylinder heads CNC eddy close chamber heads...Hughes old 256/265 solid cam...103.5 center line....630 ish lift ....crane 1.6 rockers...hughes 1111 springs.....Eddy Victor intake...MP race distributor...msd 6al...hooker 5204 headers.....
QFT 950 on E85...Turbo Action 4400 series converter...904 by me....and Tranzact Transbrake....
8 3/4 with spool...4.56 gears...B body housing narrow a couple of inches...10.5 x 29.5 M/T.
8 pt roll bar..frames tied....ladder bars and coil over shocks.
RMS UCA with adjustable strut rods and Strange brakes front and rear..
Car weight 2975 with driver.....10.72 @ 121 in Sacramento....since then ..car has victor intake instead of Mopar M1....better converter and running on E85....So...???
Well since I started the thread I guess I will post a couple
First one
91 LA 360
Junkyard bottom end (New bolts, rings, and bearings, ball honed the walls, all other parts stock), 8.8:1 compression with .028" thin head gaskets, RHS heads as sold by IMM engines, air gap intake, Custom IMM hydraulic roller cam (IIRC it was 230/230 duration at .050, 106 LSA installed on a 101 ICL, .577/.567 lift with hughes 1.6 rockers), 750HP carb, 1-5/8 headers with a 3" x-pipe exhaust and borla xr-1 mufflers, 4.10 gears, 4 speed, 28x12.5 ET streets
Car weighed around 3400lbs with me in it, ran on 87 octane gas ALL THE TIME and went a best of 12.30's at 113mph, but usually went 12.40-12.50's.
Year after, everything stayed the same except
RHS ported by Brian at IMM
Forged SRP pistons (flat tops) and Scat I beam rods, decked block, compression now at 10.25:1 (ran on 94 octane pump gas all the time)
Bigger IMM custom Hydraulic roller cam- 240/248 at .050, .630/.580 lift with 1.6 rockers, 108LSA installed straight up
Timing locked out around 34 degrees total
Went a best of 11.81 at 117mph....Usually went .80's all the time, sometimes 90's. Car was heavy and did not have enough gear with the stick (I had to drive it the 2 hour drive to the track so 4.10's had to work....4.56 would have helped for sure)
our current "backup plan" which has always served us well. 950 cfm barry grant 4150 carb, Ebrock Victor 340 intake, 273 rocker arms, iron MP heads with small stem chebby valves (1.96I, 1.6E) .547I/.554E [email protected] on the bump stick, stock 360 block, stock rods, KB pistons, stock stroke 360 crank.....forged this time around. We ran the cast crank for a long time, but a crack developed. best pass has been a 10.91. That was at an altitude track with a 904 trans and 9" Dynamic converter and 4.56 gear. Latest pass with the 727, 8" converter and 4.3 gear which worked great with our 9 sec W5 mill...... and not so good with this engine, has been a 10.98 in Vegas.
First one: 318, don't know the year of the block, crank out of a D600 truck, rods out of another 318 when they still used bushed rods, Sealed Power cast rebuilder pistons, rota-tor not balanced, angle milled 360 heads, 2.02I, 1.6E valves, Comp XTQ281S-6 cam, E-Brock Torquer II intake, 750 Holley DP, Coan 4800 stall converter, 4.88's on a spool, 275/60x15 M/T drag radials, car weighed 3030 with me in it, ran a best of 12.54 at 108 mph. The car is a 65 Barracuda.
Second one: 360, .030 over KB 107's, SIR rods, balanced internally, MP .557 cam, M1 single plane intake, Hughes ported Edelbrock heads, 1.6 rockers, PTC 5000 stall converter, Caltrac's and Mono leafs, CRT built 904 with low first gear, 4.56's on a spool, Hooser 28x9 slicks, car weight 2950 with me in it. Went 11.10 at 120 mph, still the Barracuda.
That is a good working combo! Wish my stroker had ran that good!
Nice combo's! I like that 318, proves they do have potential
I'll share my hopefully soon to be engine. Having two children has kept the extra cash tied up. Lol
4.100 bore 360 block
3.58 stock cast crank / 2.100 rod journal
6.200 sbc h beam rods
J&E flat top pistons .043-.043-3mm rings and .927 pin, 420 grams
w2 race head 2.02 / 1.60 not going to port them just bowl work
T&D 1.5 rockers
Victor w2 intake
1 7/8 headman race headers
Bullet custom grind camshaft
dur @ .050 in 275 ex 280
lobe lift in .412 ex .400
lobe sep 108
dur @ .020 in 304 ex 314
gross valve lift in .618 ex .600
lash @ .014 / .020
install at 104
direct lube lifters
This will be 378 cubic inch with 11.5-1 compression
Here's my stock stroke combo, plus some peripheral specs. I have not had the engine apart so some of the specs are unknown. Pretty old-school, right out of the Mopar Performance recipes. Previous owner from Southern California said it went a best of 11.97 but normally went 12.0.
Static compression ratio somewhere around 10.5:1, or about 180 psi
cranking.
Flat top pistons, not sure which ones.
Milodon stock replacement oil pan, not sure which pickup or pump or if it has a windage tray. PCV hooked up on one side, breather on the other side.
Valvoline ZR-1 20W-50 oil with zinc additive.
810 W2 heads, not sure what size valves. 2.05" intakes I believe. No idea on chamber size, pushrods or valve srpings either. Harland Sharp rockers.
MP .557 cam. Not sure where it's installed or what the lash is set at. Will set lash soon, probably at .024"
Victor W2 intake, no porting.
Proform 750 double pumper w. 74/84 jets, no power valve in front, pink pump cams on #2.
Carter mechanical strip pump #6270 regulated (yes) to 6.5 psi
-6 line
Stock fuel tank, RobbMc pickup with 1/2" inlet stepped down to 3/8"/-6
Blend of Cam2 100 octane unleaded and pump 93.
MP electronic distributor with Firecore HEI cap and wires, 26 degrees initial (13 on plate) + 9 degrees mechanical for 35 degrees total, all in by 2,000 rpm.
MSD 6AL with Carquest/Ford TFI coil
TTi W2 1 7/8 step headers into 3" dual exhaust, Flowmaster 40 series muffs.
Champion RC9YC plugs @ .045"
Mini starter
Pioneer balancer
Aluminum water pump, Griffin aluminum radiator, clutch fan.
"999" 904 variant with low gear set.
B+M Pro ratchet
Hughes 3,500 converter in it, not sure exactly where it stalls at.
Car originally had a 4.30:1 gear in it, now has a 4.10:1.
28" drag radials, not sure where P.O. had them set at the track.
Car originally had S/S springs with a snubber, now has Caltracs
Frame connectors, offset springs, no roll bar
Shifts at 7,000 rpm, 6,800 through the traps per P.O.
I have not raced it myself yet but I think it can do a little better than 12.0. Over the last year I took some weight out of the car, replaced all the worn out parts and made some upgrades. Hope to see consistent mid-11s.
Update....71 Demon goes 10.77 @ 121.+ with E85 and lighter driver In Vegas...
Nice Tony!!! Was Tanya at the wheel? I'll look for your update on the other thread.
I did not lose 125 lbs over night...LOL
Her Dart broke something on the driver side torsion bar ....
