73 Dart Sport 340 low vacuum due to cam change what do I need to make change? I have a A body manuel brake rod all ready. This is a disc brake car. Thanks
Buy an adapter, An E-body brake rod or extend your rod with a welded sleeve, and an Aluminum 80's 1" manual brake master cylinder. Your car will have very good braking with a 1" piston.
When you go from power brakes to manual brakes you should not reuse your power brake master cylinder. It will take much more foot pressure with your master if reused do to the larger piston size for the power unit.
