Power Brakes
Dan the man
missouri
How much cam can be used in a 318 and still have the power brakes to function properly.
as much as you like, just fit an electric or belt driven vacuum pump to
I don't want to go real crazy with a big cam as the car is going to be a cruiser. I was thinking about something like 220*-224* duration at 0.050" lift.
You should be ok with 220 @ 050; more compression helps by increasing idle vacuum.
I had a 284°/.484" Mopar cam in the 383 that was in the ex-PoPo Dippy, engine needed a minute or two when it was chilly out before the vacuum was enough to go full assist, that cam is ~240°@.050. The 'teener will probably be the same around the 230°'s with a similar profile cam. Good manual brakes are the best, My choice for an A-body of Mine every time, no worries there.
